Drewmama
Jun 27, 2019Guide
Connect device to 2.4ghz only
I have a RBK22. My Ring doorbell can only connect to 2.4ghz. My Echo Show can connect to both 2.4 and 5ghz and automatically connects to 5ghz. However I need the Echo Show to connect only to 2.4ghz i...
CrimpOn
Jun 27, 2019Guru - Experienced User
I have no doubt that the support people were trying to be helpful. Dealing with "mesh" WiFi systems is confusing. There is definitely something wrong. The hard part is to figure out what exactly isn't working correctly. Alas, I have neither a Ring doorbell nor an Echo Show. (Luddite family, sorry). Best advice I have is to go back to the the instructions about how to connect the Echo Show to the Ring doobell. How does the Echo even know that a Ring doorbell is on the network? Does it have a "name"? Can you put in an IP address?
Good Luck
