Drewmama
Jun 28, 2019Guide
Connect device to 2.4ghz only
I have a RBK22. My Ring doorbell can only connect to 2.4ghz. My Echo Show can connect to both 2.4 and 5ghz and automatically connects to 5ghz. However I need the Echo Show to connect only to 2.4ghz i...
Drewmama
Jun 28, 2019Guide
Yes, that is what I did except I didn't uncheck "Enable WMM.."
Will_T
Jun 28, 2019Apprentice
Thanks Drewmama. I think that after I unchecked that box, I needed to disconnect and reconnect the 5G connected devices to force them to 2.4. For tonight at least I got it working by reducing the power. I have asked about that issue in another thread so as to not distract from the help you are getting here. I am watching this as I will be helping my son set up a new Orbi with a very similar doorbell and system as you so hopefully I will learn something here!
