alokeprasad
Oct 27, 2023Mentor
Connect directly to satellites via web interface.
I can see the satellites as connected in the web interface of the router: However, the firmware update (in Administration) page of the router does not show the two satellites even after a long...
- Oct 30, 2023
The problems with the satellite connection and access was solved by unplugging the ethernet cables from the back of the satellites. That made the wireless connection between the RBR and the 2 RBS's unstable. The automatic updates through the web (or iOS app) did not detect the availability of the "new" firmware 8 moths after the release of the firmware.
That said, folks should bring the satellites one at a time into the same room as the RBR, reset the satellites and manually update the firmware using the downloaded .IMG files.
Oct 29, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
alokeprasad
Oct 30, 2023Mentor
- FURRYe38Oct 30, 2023Guru - Experienced User
Glad you got it working. Enjoy.
