debrasunshine
Nov 30, 2018Follower
Connect external hard drive to Satellite LAN port
Can an external hard drive be connected to a Satellite’s LAN port to make the drive wirelessly available on WiFi network?
Nov 30, 2018Guru - Experienced User
Does the external drive support a LAN port? if so, I would presume it works. I would contact the mfr of the drive to check what is supported.
