RVcamper's avatar
RVcamper
Follower
Jul 30, 2023
Connect LBR20 to camping wifi (or any existing wifi instead of LTE)
Can you connect the LBR20 to an existing wifi signal?
My setup: LBR20 LTE router hooked up to 2 external LTE antennas. These are factory pre-wired antennas that came with my travel trailer (Winegard 360+). Works pretty good with my cel sim card.
Question: one of the antennas on my RV is a wifi antenna, meant to boost the free wifi offered in most camping sites and send it to a router inside the trailer. I want to connect this wifi booster antenna to the LBR20 to sometimes use the existing wifi instead of LTE.
However I do not see any option in the app to connect the LBR20 to an existing wifi signal.
  • plemans's avatar
    Using a wifi as the WAN requires WISP mode.
    https://wifi-settings.com/wireless-routers/wisp-mode/
    There are other routers that support it and some mobile ones. Not sure if the lbr20 is one because I don't have one to play with. My understand of it is it can use hardwired connection or cellular. Not another wireless signal.
    Not saying you couldn't pickup up a cheap gl.inet router and use its wisp mode and hardwire that to the lbr20.
    • KevinLiT's avatar
      KevinLiT
      NETGEAR Moderator
      Hello RVcamper ,
      Welcome to the NETGEAR Community!
      The LBR20 supports wired internet and mobile broadband. An ethernet cable will be required to use internet networks as the LTE failover.
      Best,
      Kevin
      Community Team
