MagJo
Jul 27, 2021Aspirant
Connect ORBI 850 to existing Wifi, then network cable into PC
Dear all i would like to connect to an external wifi with my pc that has no built in wifi. I have an Orbi rbs 850 satelite and would like to hook it up to the wifi and then use cable between it ...
Jul 27, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Not possible. RBS850 only conect to a RBR7 or 8 series router.
Thank you.
