MagJo
Jul 27, 2021Aspirant
Connect ORBI 850 to existing Wifi, then network cable into PC
Dear all i would like to connect to an external wifi with my pc that has no built in wifi. I have an Orbi rbs 850 satelite and would like to hook it up to the wifi and then use cable between it ...
schumaku
Jul 28, 2021Guru - Experienced User
Not aware an Orbi Satellite can be used as a wireless adapter or whatever kind, and even less as a mobile router.
