RonSwanson
Jan 26, 2021Aspirant
Connect Orbi CBR40 router to fiber optic cable
Just switched from comcast cable to AT&T fiber optic. CBR40 router only has a coax input. How can I get the fiber optic signal into the CBR40 router? Is the a coax to fiber optic converter? Alternati...
RonSwanson
Thanks! Do i connect the RBK via a CAT5 from the AT&T router to the RBK??
Jan 26, 2021Guru - Experienced User
Yes. CAT6 would be recommended and best. CAT5 is older and doesn't support 1000Mbps connection rates well.
- RonSwansonJan 26, 2021Aspirant
THANK YOU!
- FURRYe38Jan 26, 2021Guru - Experienced User
:smileywink:
I have two RBS satellites. Will they connect to the RBK router?
