titib
Apr 26, 2019Aspirant
Connect Orbi RBK20 base and satellite with ethernet
Hello,
I've two questions:
1) I'd like to know if it's possible to connect the base and the satellite of Orbi RBK20 via the Ethernet port (there are too far away to be connected by wifi)...
Apr 26, 2019Guru - Experienced User
Yes you can:
Just make sure the switch is non managed and non Green Ethernet. If you do have a managed switch, be sure ALL IGMP protocols are disabled on the managed switch.
