brewer_ashley
Jul 21, 2019Follower
Connect orbi without a modem
Unable to connect Orbi since is no modem. House is hard wired & existing router is plugged into wall from ethernet.
Jul 21, 2019Guru - Experienced User
This would be a double NAT condition which isn't recommended if you have router in front of the Orbi router. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first, then #3 if #2 doesn't work for you...
