ChinoMorales
Oct 06, 2019Tutor
Connect Ring Base station(Ring Security system) wired.
Hi there, I'm installing Ring Security system and I would like to know if it's ok to connect the Base Station 'wired' to one of my Orbi satellites, if not I take the wireless route. Thanks a lot i...
- Oct 09, 2019
Thanks a lot,
Ring security system installed and working seamlessly wired to Orbi satellite.
Oct 09, 2019Guru - Experienced User
Yes that should work. Let us know how it goes if you try this.
ChinoMorales wrote:Hi there,
I'm installing Ring Security system and I would like to know if it's ok to connect the Base Station 'wired' to one of my Orbi satellites, if not I take the wireless route.Thanks a lot in advance.
ChinoMorales
Oct 09, 2019Tutor
Thanks a lot,
- FURRYe38Oct 09, 2019Guru - Experienced User
Good to hear. Please mark your post thread as solved so others will know.
Enjoy. :smileywink:
