mrudm
Jan 11, 2017Tutor
Connect Satellite via Ethernet
I'm considering buying a 2 unit Orbi (router + 1 satellite). I have an existing home ethernet network, so I would connect the satellite to the router via 1 GB ethernet, giving a faster more reliable ...
Retired_Member
Mar 21, 2017st_shaw spent the entire afternoon setting up the Unifi cloud key and the network. Well, it was truly worth it: I now have full WiFi coverage in and around the house, using 4 AC Pro APs. Took me a long time to find the optimal channel and TX power combo but now it works and I'm happy. Especially since I was able to reduce RF exposure around the kids to an absolute minimum - except for the outdoor AP in the garage, everything runs at 10dbm and below.
st_shaw
Mar 21, 2017Master
Retired_Member That's awesome! Good for you. I really like my Ubiquiti WAP system. I hope you like yours.
I also have an EdgeRouter, but that thing can be insanely complex to get setup. I'm not sure I would recommend that to anyone but a Linux guru.
