Shaqz
Dec 02, 2022Aspirant
connect satellites from one orbi set to another RBR50 set with RBS20
I just got a "new" orbi set . I have just set up a rbr50 with 2 rbs50 and one rbs20 satellites. It is working fine but i would like to extend the range. I used to have a rbr20 with two rbs20 ...
CrimpOn
Dec 02, 2022Guru - Experienced User
Do a Factory Reset on the satellite you want to move to the new system. Then, go through the Add Orbi Satellite (bottom menu item) on the Orbi web browser interface (http://orbilogin.net
Shaqz
I tried with factory reset. With a pin on the back?
I have to use the orbilologin.com?
- CrimpOnDec 02, 2022Guru - Experienced User
Yes. Pin in the tiny "Reset" hole on the back.
Unless you follow the directions on the web interface, the satellite will simply wait for the original router to appear.
- ShaqzDec 02, 2022Aspirant
I still can't make it work. Keep on getting solid magneta color the satellite.
For how long should i reset. Untill the small light it blinks amber?
Keep on not making it.
Should i hold in the sync button all the time? Or is it any other thing that i am doing wrong?
