Shaqz
Dec 02, 2022Aspirant
connect satellites from one orbi set to another RBR50 set with RBS20
I just got a "new" orbi set . I have just set up a rbr50 with 2 rbs50 and one rbs20 satellites. It is working fine but i would like to extend the range. I used to have a rbr20 with two rbs20 ...
CrimpOn
Dec 02, 2022Guru - Experienced User
Yes. Pin in the tiny "Reset" hole on the back.
Unless you follow the directions on the web interface, the satellite will simply wait for the original router to appear.
Shaqz
I still can't make it work. Keep on getting solid magneta color the satellite.
For how long should i reset. Untill the small light it blinks amber?
