Shaqz
Dec 02, 2022Aspirant
connect satellites from one orbi set to another RBR50 set with RBS20
I just got a "new" orbi set . I have just set up a rbr50 with 2 rbs50 and one rbs20 satellites. It is working fine but i would like to extend the range. I used to have a rbr20 with two rbs20 ...
KevinLiT
Dec 02, 2022NETGEAR Moderator
Hello Shaqz,
Welcome to the NETGEAR Community!
Please try resetting the satellites then, administer the syncing process when the satellites are next to your RBR50. Please SYNC one satellite at a time for the best results. Please ensure that all satellites are on the same firmware.
Please navigate to the link below for additional information about adding your satellite to your existing Orbi system via your Orbi app:
How do I connect a satellite to my Orbi router? | Answer | NETGEAR Support
Please let me know if you have any additional questions!
Best,
Kevin
Community Team
Shaqz
Thank you.
I have tried that.
I have a new set of RBR50. With 3 satellites. These 3 I managed to connect. One of these were a rbs20 adon. This is connected aswell.
But the problem is to connect my old RBS20 satelittes to the rbr 50.
I have tried factory resetting and syncing several times, without getting anything else than solid magneta light.
Would appreciate all solutions to solve this.
Thanks.
- ShaqzDec 02, 2022Aspirant
After resetting the sattelite.
the power light is blinking red and ring is blinking white.
It is said that i should wait til it is solid white before i sync. For how long should i wait. It is around 15 minuttes now....
- CrimpOnDec 02, 2022Guru - Experienced User
This is not good. Do both of the RBS20 satellites do this?
just one of them.
power flashes red and the ring flashes white. What does this mean? came after resetting
the other power light is solid green and the ring flashes white. waiting for it to stop flashing white and get solid white. Then i can try to sync this. and then turned solid magneta. can i try to sync ut now? it says it should be solid white
