Shaqz
Dec 02, 2022Aspirant
connect satellites from one orbi set to another RBR50 set with RBS20
I just got a "new" orbi set . I have just set up a rbr50 with 2 rbs50 and one rbs20 satellites. It is working fine but i would like to extend the range. I used to have a rbr20 with two rbs20 ...
Shaqz
just one of them.
power flashes red and the ring flashes white. What does this mean? came after resetting
the other power light is solid green and the ring flashes white. waiting for it to stop flashing white and get solid white. Then i can try to sync this. and then turned solid magneta. can i try to sync ut now? it says it should be solid white
CrimpOn
Dec 02, 2022Guru - Experienced User
Yes. Go for it.
- ShaqzDec 02, 2022Aspirant
It didn't work.
I restarted the flashing the red flashing one. Did a new factory reset. And it is alive again. But can not connect to the rbr50. It turns to solid magneta.
When i start them. They flash white. And then turn to magneta.
I have tried syncing them while flashing, and while solid magneta. But does not work any of them.
Looks like they are to faithful and just want the old rbr20.
Is there anyone that knows a way to sync them to a the new router i set up. rbr50??
would be forever thankful, if i someone would help out. Thanks.
