Shaqz
Dec 02, 2022Aspirant
connect satellites from one orbi set to another RBR50 set with RBS20
I just got a "new" orbi set . I have just set up a rbr50 with 2 rbs50 and one rbs20 satellites. It is working fine but i would like to extend the range. I used to have a rbr20 with two rbs20 ...
Shaqz
Please, red the further post. IIf you have any idea what to do please let me know. thanks.
KevinLiT
Dec 02, 2022NETGEAR Moderator
Hello Shaqz,
Thank you for your post!
Which firmware is currently installed on your router and satellites?
Best,
Kevin
Community Team
- ShaqzDec 03, 2022Aspirant
They all have the same firmware
V2.7.3.22
Versjon
V2.7.3.22
I just connected the old RBR20 set with the satellites. It automatically finds this satellites. And both satellites are working.
But the rbr50 can not find these satellites??? IT has to be a way of fixing this?
I am trying to update it all to 2.7.4.24.
Do i have to reset the satellites afterwards or will this make them go back to the old versjon?
