Naskar_SP
Jan 21, 2021Aspirant
Connect the router to the modem
Hi! This is a very simple question, documentation states that I have to connect the rbr20 directly to the router. Since my router is located into a wardrobe (yes, that’s the point my wifi is so ...
- Jan 21, 2021
Since my router is located into a wardrobe (yes, that’s the point my wifi is so poor!), is it possible connect the rbr to a rj45 wall port?The ethernet cable connecting Orbi to modem can be up to 300ft. long. As long as the connection goes from the Orbi WAN port to the modem ethernet port, it doesn't matter how many pieces of cable it takes. For example:
Orbi WAN port--<ethernet patch cable>--RJ45 jack--<ethernet cable in wall>-- patch panel RJ45 port --<ethernet patch cable--> modem ethernet port.
CrimpOn
Jan 21, 2021Guru - Experienced User
Naskar_SP
That’s what I want!
Thank you very much!
