BraveDaveNYC
Oct 29, 2020Tutor
Connect three Orbis in-line
Hi folks, I have RBR50 router and RBS40 satellite. They work ok, but are a bit too far apart. So I'm adding an RBW30 in between. How do I create a daisy-chain where: RBS40 satellite >>conne...
DeanB1452
Oct 29, 2020Apprentice
Log into your router through the web interface and go to wireless settings in advanced setup. You should see a box in backhaul topology to enable daisy-chain topology. Your router will choose the best option based on signal strength and may daisy-chain or connect to each one directly.
