BraveDaveNYC
Oct 29, 2020Tutor
Connect three Orbis in-line
Hi folks, I have RBR50 router and RBS40 satellite. They work ok, but are a bit too far apart. So I'm adding an RBW30 in between. How do I create a daisy-chain where: RBS40 satellite >>conne...
Oct 29, 2020Guru - Experienced User
https://kb.netgear.com/000048458/What-is-daisy-chain-and-how-does-it-work-with-my-Orbi-WiFi-System
https://kb.netgear.com/000048460/How-do-I-disable-daisy-chain-topology-on-my-Orbi-WiFi-System
https://kb.netgear.com/000048459/How-can-I-see-if-my-Orbi-WiFi-System-is-using-daisy-chain
