Steve54
May 04, 2019Initiate
Connect to 2.4G on Orbi
I have several devices that need to connect to the 2.4G band. I've been doing this by connecting to a Netgear extender with a different SSID that is on the 2.4G band but I would rather connect to the...
- May 04, 2019
Try to disable the 5GHz band SSID broadcast under >> ADVANCED >> Advanced Setup >> Wireless Settings. Please see below:
This will work for some devices that can't find hidden SSID's. This will not work with smart phones and other smart devices:
ekhalil
May 04, 2019Master
- Steve54May 08, 2019Initiate
So far this seems to have worked
