junior48603's avatar
junior48603
Follower
Mar 28, 2020
Connect to a specific RBR20 satellite
Hello, we have an Orbi RBR20 system and I am wondering if there is a way to make a device connect to a specific satellite. We have a satellite upstairs in our home yet a couple of devices will only connect to the router on the main floor even when they are much closer to the satellite (for example 10 feet from upstairs satellite vs. 30 feet from main floor router). I have tried having the device forget the wifi network and then reconnect with the device right next to the satellite with no success. Looking for any other suggestions.
Thanks!
    Yes, it's possible with RBR50 series, not sure about RBR20 series.  You can check out this thread, this thread, and this thread
  • Wifi devices choose and pick there signals to connect to, even if you reconfigure any Orbi or any wifi system, it's up to the devices to pick and choose where they connect too.
    Thanks!
