jeffish
Jun 03, 2019Aspirant
Connect to Apple Time Capsule Remotely on Orbi RBK43
Hello, I switched from an aging Time Capsule to Orbi. I used to connect remotely to the hard drive on the Time Capsule and can't seem to access the drive anymore. I attempted to port forward but ...
ekhalil
Jun 04, 2019Master
- Which port are you using to reach the drive remotely?
- Please activate UPnP in Orbi and ATC
- Check out this article https://support.apple.com/en-in/HT204618
- jeffishJun 04, 2019AspirantUPnP is activated on the Orbi, the ATC does not have that functionality.
I have BackToMyMac set up, however I’m attempting to connect with a mobile device using either SMB or AFP.
I’ve tried a couple different ports including the ones listed on the UPnP Orbi page.
