jeffish
Jun 03, 2019Aspirant
Connect to Apple Time Capsule Remotely on Orbi RBK43
Hello, I switched from an aging Time Capsule to Orbi. I used to connect remotely to the hard drive on the Time Capsule and can't seem to access the drive anymore. I attempted to port forward but ...
ekhalil
Jun 04, 2019Master
- Which port are you using to reach the drive remotely?
- Please activate UPnP in Orbi and ATC
- Check out this article https://support.apple.com/en-in/HT204618
jeffish
Jun 04, 2019Aspirant
UPnP is activated on the Orbi, the ATC does not have that functionality.
I have BackToMyMac set up, however I’m attempting to connect with a mobile device using either SMB or AFP.
I’ve tried a couple different ports including the ones listed on the UPnP Orbi page.
- FURRYe38Jun 04, 2019Guru - Experienced User
- jeffishJun 04, 2019AspirantThe ISP is Spectrum, they provided an UBEE DVW32CB
Your ISP modem already had a built in router and wifi:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
