jeffish
Jun 03, 2019Aspirant
Connect to Apple Time Capsule Remotely on Orbi RBK43
Hello, I switched from an aging Time Capsule to Orbi. I used to connect remotely to the hard drive on the Time Capsule and can't seem to access the drive anymore. I attempted to port forward but ...
jeffish
Jun 04, 2019Aspirant
Thanks for the quick answer. You are correct, the modem has a built in router, however my ISP charges a monthly fee to utilize it, since I Opted out, they place the modem in Bridge mode which I confirmed through logging in.
I believe that would cover the 1st option you have referenced
Jun 04, 2019Guru - Experienced User
Ok, making sure which mode the modem was in.
You might check with Apple and see about using some port foward configurations for Time Capsule in the RBR to see if any of there configurations will help get the TC remote connection going. There maybe some specific Port Forwarding values needed.
