loremipsum
Sep 08, 2017Aspirant
Connect to router (RBR50) with ethernet
I am able to connect to the satellite with an ethernet cable; however, I am NOT able to do the same with the router. For a wired connection do I need to set my laptop's IP to a particular static IP?
DarrenM
Sep 11, 2017Sr. NETGEAR Moderator
Hello loremipsum
What is happening with your wired connection when plugged into the router? Do you not get a IP address on your laptop?
DarrenM
- peteytestingSep 11, 2017Hero
and have you tried all 3 available lan ports on the router , i did have a strange issue at one time where one of the ethernet ports wouldnt work , i think it was port 4
- loremipsumSep 12, 2017Aspirant
I did try two different ports. When I was connected I couldn't reach the router's login (orbilogin.com) or get any website to load.
- OrbiPhilipSep 14, 2017Luminary
I just connected my FS & AD server to port 4 and made RDP connections, ran speedtest, etc. Worked fine. 48 port switch connected to port 1. Ports 2 & 3 are open.
