Gebla
Sep 04, 2019Apprentice
Connected but no internet
In the past i made a split into a ssid on 2.4 and a ssid to 5 ghz because i had a problem with several devices on 5 ghz. On 5 ghz devices show connected to wifi but they get no or very slow internet. ...
Sep 05, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
NG does not support the separation or splitting of the SSID.
Has a power OFF of the ISP modem and Orbi for 30 seconds then back on with the modem first then the Orbi after that?
How about a factory rest and walk thru the Orbi setup wizard...
On recommendations by Netgear i did a reset and new setup yesterday. Last night my tv (now on 5) during netflix streaming showed buffering 4 times, on 2.4 it never showed buffering. And this morning 2 different phones had no internet. Both phones where powered on during the night. Only after wifi off and on and a few minutes later the phones suddenly get internet again.
Additionally one laptop (Surface Book 1) had issues getting internet on 5 Ghz.
All the internet issues did not exist when the devices connect to 2.4.
So my wifi system is crap and does not work reliable on 5 ghz.
I do not want to do all kind of basic diagnose as i have done it already and on 2.4 i have no issues. I am happy to create log fikes for you. Please instruct me how to collect these log files.
- GeblaSep 05, 2019ApprenticeTried everything already. Distance between devices is good. Latest firmware 2.something and did factory reset yesterday.
It is the crap firmware of netgear.- FURRYe38Sep 05, 2019Guru - Experienced User
So what is the distance between the RBR and RBS, specifically?
Has a factory reset and setup from scratch been performed since last update?
Please try the suggestions presented.
RBR and SBS are about 10 meters apart and SBS and SB are 10 meters apart. Both wired into the RBR.
