Gebla
Sep 04, 2019Apprentice
Connected but no internet
In the past i made a split into a ssid on 2.4 and a ssid to 5 ghz because i had a problem with several devices on 5 ghz. On 5 ghz devices show connected to wifi but they get no or very slow internet. ...
Gebla
Sep 05, 2019Apprentice
Tried everything already. Distance between devices is good. Latest firmware 2.something and did factory reset yesterday.
It is the crap firmware of netgear.
Sep 05, 2019Guru - Experienced User
So what is the distance between the RBR and RBS, specifically?
Has a factory reset and setup from scratch been performed since last update?
Please try the suggestions presented.
- GeblaSep 05, 2019Apprentice
RBR and SBS are about 10 meters apart and SBS and SB are 10 meters apart. Both wired into the RBR.
- FURRYe38Sep 05, 2019Guru - Experienced User
Are the RBS directly connect to the RBR or are they connect to a LAN switch then to the RBR? What is the Mfr and model# of the ethernet switch if one is in the configuration?
Is Daisy Chain disabled?
Are you getting internet at the RBR and not the RBS or the entire system doesn't get internet?
- GeblaSep 06, 2019Apprentice
Daisy chain is enabled and I now reduced the system from 3 RBS to 1 RBS directly wired into the RBR. Still issues with 5 GHZ. Next step is moving the wired RBS into a non wired connection to the RBR and see if it will work.
Got in contact with Netgear support but they refuse warranty because I used Telnet on the devices (even after me doing factory reset support is declined). Unfortunately my experience with Netgear is now even worse. I got a bad product that does not work and they refuse warranty. Go Netgear!
