Mm806
Apr 01, 2023Aspirant
Connected Device change from extender to router
I have a Roku that is connected to the orbi satellite but I would like to connect it to the router wirelessly. Is this possible? If so how? My roku does not have a wired connection by the way
- Apr 01, 2023
Mm806 wrote:
Sorry by extender I meant satellite. A router does not send out a Wi-Fi signal ? How do I connect to my router wirelesslyOrbi routers and satellites broadcast exactly the same WiFi name (SSID) on both 2.4G and 5G WiFi channels.
WiFi devices include networking software which examines the signal from every available access point (router, satellites, neighbors), ranks them somehow, and chooses one to connect with. When it already "knows" the WiFi password and is set to "connect automatically", it just does it.
Does the Roku not perform correctly?
Mm806
If I disconnected the extender completely left the router on and ran the roku set up would it then connect to it?
CrimpOn
Apr 01, 2023Guru - Experienced User
Extender can have multiple meanings.
- If the Roku connected to an Orbi satellite, then I doubt anything would change.
- If the Roku is connected to a "WiFi Extender" (not to a satellite), then it might.
- Mm806Apr 01, 2023AspirantSorry by extender I meant satellite. A router does not send out a Wi-Fi signal ? How do I connect to my router wirelessly
- CrimpOnApr 01, 2023Guru - Experienced User
- Mm806Apr 01, 2023AspirantI just wanted a stronger signal for my roku. I u plugged satellite and restarted roku and it automatically connected to the main router 👍🏽
