mbski's avatar
mbski
Guide
Oct 28, 2016
Connected devices all shown as wifi
Software update  V1.3.0.12 did not correct the connected devices type. (Wired vs wifi) Prior to this update the device list was correct for wired vs. wireless. After update  V1.3.0.12 all connected devices show wireless. It even states in the update fixes, that this was in the update, NOT. I have 17 wired devices,(smarthome) and 9 wifi devices, every single device shows wifi?
  • have you got the advanced attached devices view tyrned on ?
    see
    orbilogin.com/debug.htm
  • Ok to clarify, using the netgear app all of the connected devices show WiFi connected. Prior to SW update 1.0.3.12 they reflected the correct connection type. Wired, WiFi. In the router GUI they show correctly.
