TedHL's avatar
TedHL
Tutor
May 29, 2017
Connected devices list
I am curious how reliable the connected devices list is for the ORBI. I have 8 SONOS devices connected to my network.  I have network scanners that run on my iPhone and my iMac that reliably find all 8 of the SONOS devices. However, the connected devices listed on orbilogin.com rarely show one of the devices while it seens to reliablly list the other 7. The one that almost never shows is a SONOS:SUB. I haven't the foggiest idea what is different about the SONOS:SUB that would cause this to happen. Especially when the other network scanners find it every time. All of the SONOS devices work perfectly on the ORBI network (including the SUB).
Thanks
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello TedHL
    If that sonos device is connected to a satellite unit you may want to log into the Ip address of the satellite and check its connected devices.
    DarrenM
    • TedHL's avatar
      TedHL
      Tutor
      There is actually only one connection to my network for the SONOS devices. That is a direct wired connection from a SONOS : BOOST to the main ORBI unit. The other SONOS devices connect through the SONOS : BOOST.
      All of the SONOS devices show as a wired connection in the ORBI Connected Devices list because of the wired SONOS : BOOST connection. That is what is strange about the SONOS : SUB. It connects the same as all of the other SONOS stuff through the BOOST and the ORBI list reliably lists all of them except for the SUB.
      Go figure...
      • CrimpOn's avatar
        CrimpOn
        When you say "reliably", do you mean that sometimes that device shows up and other times it does not show up?  I have some IP cameras that all come into the Orbi through a single wired port, and ONE of the cameras "appears" and "disappears" from the Connected Devices list.
