andygodber
Apr 02, 2018Tutor
Connected devices on Satellite shows fewer than actually connected
Per the title, the web config of connected devices on the satellite shows less than those actually connected to it. For example, Im currently seeing 5 devices in 2.4G and 5G bands showing on the web...
Apr 02, 2018Guru - Experienced User
Was a factory reset performed after upgrading to v2.1.3.4? If not, then there maybe some residual data left from prior FW and configuration. IT's highly recommended to factory reset both router and satllite(s) and setup from scratch.
- andygodberApr 02, 2018Tutor
yes, full reset done.
