andygodber
Apr 02, 2018Tutor
Connected devices on Satellite shows fewer than actually connected
Per the title, the web config of connected devices on the satellite shows less than those actually connected to it. For example, Im currently seeing 5 devices in 2.4G and 5G bands showing on the web...
Apr 03, 2018Guru - Experienced User
Try viewing the page with a different brower to see if there are any differences.
I would do this. turn off all connected devices that connects to the satellite. Should see nothing connected. then add one device. check status. graduate adding a device and check status...
- andygodberApr 03, 2018Tutor
Browser makes no difference.
Can you confirm you see the same number in the web interface and CLI on the satellite?
And how many devices connected to the satellite?
