MarkWorsnop
Nov 03, 2017Aspirant
Connected devices shows wired on my LAN. V2.0.0.74
Why do I see all the wired devices on my LAN that are NOT connected to the ORBI? They all say wired. Its nice to see this, but that are not connected directly to the ORBI and is really misleading. ...
DarrenM
Nov 10, 2017Sr. NETGEAR Moderator
Hello MarkWorsnop
If the orbi is your main router it will be assigning IPs to all those devices so it would show up in the attached devices.
DarrenM
MarkWorsnop
Nov 10, 2017Aspirant
ORBI is NOT the main router. It would make sense then, but its not
- DarrenMNov 14, 2017Sr. NETGEAR Moderator
if its not the main router do you have orbi running in AP?
DarrenM
- MarkWorsnopNov 14, 2017Aspirant
Yes its in AP (Bridge) mode
Thanks for reporting that you are still seeing that issue it was thought to be fixed I will report this.
DarrenM
