dtskip
Dec 30, 2018Guide
Connected devices stuck on 2.4G? Is there no way to force 5G?
What gives? I thought devices with 5Gz support were supposed to automatically connect via 5Gz?
Two of those devices on 2.4G 100% support 5G and are right next to the Sattelite, and I'v...
Dec 30, 2018Guru - Experienced User
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using? Try WPA2 and AES only.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Disney Circle: https://community.netgear.com/t5/Orbi/WARNING-Firmware-2-2-1-210-is-junk/m-p/1667485/highlight/true#M45926
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
Try turning down the power on the 2.4Ghz radio from 100% to 50% and see. Advanced Tab/Advanced Settings/Wireless Settings
- CrimpOnDec 30, 2018Guru - Experienced User
The Orbi broadcasts only one SSID because the product is designed to track the client and decide whether it will work better connected to 2.4G or 5G (and whether it will work better connected to the main router or the satellite). People should not have to say, "oh, I'm in the den now, I should change to the "den SSID". "Oops, now I moved to the patio, I should change to the patio SSID." This change doesn't happen instantly. In digging around the Orbi configuration files, I found timer settings which control how often the Orbi reevaluates connections. (I don't understand them, but I did see them.) People have reported in the forum that devices "change" after a while. In my house, for example, a device may connect to the main router and then I go downstairs and closer to the satellite. I think, "Hey, stupid Orbi, why are you not switching the device from the router to the satellite?" My imagination is that the Orbi is saying, "this device is working just fine connected to the router, I'm not ready to force a change YET." The same thing could happen between 2.4G and 5G. Orbi could think, "nah. No reason to switch yet."
Or, I could be just totally wrong.
Perhaps you could do an experiment and leave the device alone for a while and see if it "moves".
- JoeCymruDec 30, 2018Virtuoso
I had an issue with my main Samsung TV wanting to stay hooked up at 2.4GHz to the router clear acros the house rather than 5G to the satellite no more than 8 feet away. I rebooted the TV, and everything got friendly again between the TV and the satellite on 5GHz. In this case I blame the device (the TV). Also one had one of our phones pull the same stunt. Just power cycled that one. Perhpas not your issue, but most of the time the mobile devices switch correctly.
