Silk82
Apr 27, 2020Tutor
Connected (no internet access)?!?
I just did a factory reset and updated both router and satellite to the new 2.5.1.16 firmware. Im still having issues with the internet, it suddenly goes offline. See picture, this is my phone. Th...
BigRune
Apr 27, 2020Apprentice
You had the same problems before reset and upgrade?
Silk82
Apr 30, 2020Tutor
Yes, something is wrong with the RBS. Ive done some more testing now. Not sure whats going on, but internet goes offline from time to time when RBS is added as satellite. Ive done up/downgrades of fw. Factory resets, nothing helps.
Plesse check new post/link as posted above.
