BMcB
Jul 30, 2018Follower
Connected, no internet
It's appears that my Orbi Satelitte is on with a blue light but isn't transmitting a wifi signal. I've rebooted and tested and while I get almost 300 Mbs from the router. The satelitte isn't giving m...
Jul 30, 2018Guru - Experienced User
Try resetting the satellite. Hold in the reset button for 15 seconds until the top led turns on Amber. Then let go. Wait for the slow pulsating WHITE led. Then re-add to the router. If this fails, I would contact NG support and get help. Ask for an RMA if needed.
