Littleden
Jun 07, 2020Aspirant
Connected to ORBI (access to internet) but can't get online
Hi all, So I have an Orbi RBR50 as the router, all the devices connect and have access to the internet. However, when I connect my PC to the network, it says "connected, secured" but I can't get ...
Jun 08, 2020Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #1...
