Ling5321
Oct 25, 2019Aspirant
Connected to Orbi but no internet
Right now I have three rbr50 units connected to my switch and I am currently using them as Access points. I have a strong stable connection to all my Orbi units with my devices never losing connectio...
Retired_Member
Oct 25, 2019
Ling5321 wrote:Right now I have three rbr50 units connected to my switch and I am currently using them as Access points. I have a strong stable connection to all my Orbi units with my devices never losing connection to it. But all my devices in the home are constantly losing connection to the internet. What could be the cause of all of this?
you have 3 Orbi routers (??) connected to a switch...? Why???
- Ling5321Oct 25, 2019Aspirant
My apologizes, I have one rbk50 2pack and one rbk20 2 pack.
- Retired_MemberOct 25, 2019
Ling5321 wrote:My apologizes, I have one rbk50 2pack and one rbk20 2 pack.
OK....I would try the set up without the switch and see what that does. Some have reported problems with certain switches.
- CrimpOnOct 25, 2019Guru - Experienced User
I'm sure there is "a story" behind having three RBR50's and no satellites. Meanwhile, please describe how these Orbi's are connected.
What is the brand/model of internet modem/router?
Are there devices not connected to the Orbi's? (desktops, laptops, NAS servers)
If so, do these devices also lose internet periodically?
Is there a distinct "pattern" to the disconnection, or does it appear to be random?
Currently my setup is internet to an xfinity modem/router box to a switch to the 3 orbis.
For example, If I am connected to the orbi on my windows 10 laptop I will not be able to access the web at all and if I were to be on my iphone I would only be connected sometimes to different apps.
I have a 2.4 ghz signal from my xfinity box that is always working. When I am connected to this signal I can be on the internet uninterrupted.
- FURRYe38Oct 25, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
