Ling5321
Oct 25, 2019Aspirant
Connected to Orbi but no internet
Right now I have three rbr50 units connected to my switch and I am currently using them as Access points. I have a strong stable connection to all my Orbi units with my devices never losing connectio...
CrimpOn
Oct 25, 2019Guru - Experienced User
I'm sure there is "a story" behind having three RBR50's and no satellites. Meanwhile, please describe how these Orbi's are connected.
What is the brand/model of internet modem/router?
Are there devices not connected to the Orbi's? (desktops, laptops, NAS servers)
If so, do these devices also lose internet periodically?
Is there a distinct "pattern" to the disconnection, or does it appear to be random?
Ling5321
Currently my setup is internet to an xfinity modem/router box to a switch to the 3 orbis.
For example, If I am connected to the orbi on my windows 10 laptop I will not be able to access the web at all and if I were to be on my iphone I would only be connected sometimes to different apps.
I have a 2.4 ghz signal from my xfinity box that is always working. When I am connected to this signal I can be on the internet uninterrupted.
- FURRYe38Oct 25, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
