wizard2002
Dec 13, 2021Aspirant
connected without internet
Since 2 days my internet is conected without internet intermitent. I tried to switch chanel without success and also run restart on the wifi too... no improvement. 3 month support while i have 1 year...
michaelkenward
Dec 14, 2021Guru - Experienced User
What modem gives you the Internet connection? Is it working OK?
What firmware version do you have on the RBR50v2.
What does "connected without Internet intermittent" mean?
So far you have provided very little useful information.
You can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
They are there for a good reason.
wizard2002
Dec 14, 2021Aspirant
ISP Modem is: Technicolor CGM4140COM
the modem is connected on bridge mode
What does "connected without Internet intermittent" mean?: I mean i no longer have internet on wifi on smartphone (galaxy s20) and I can see the small exclamation mark on the upper right corner of my device on the 4 network strength bars. When I press above it says: connected without internet. It happens randomly, intermittently.
Firmware orbi : V2.7.3.22
- wizard2002Dec 14, 2021Aspirant
i have run a 10 seconds reset (unplug power) of both devices
- michaelkenwardDec 14, 2021Guru - Experienced User
Have you confirmed that?
Does the RBR50v2 show that it has an Internet connection?
What colour is the Router ring LED?
How about a network reboot?
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
I mean i no longer have internet on wifi on smartphone (galaxy s20) and I can see the small exclamation mark on the upper right corner of my device on the 4 network strength bars. When I press above it says: connected without internet. It happens randomly, intermittently.So, not intermittent.
Which "network strength bars"? Wifi or cell network?
"connected without internet" could be either.
Can the device see the wifi SSID?
What about other wifi clients?
- wizard2002Dec 14, 2021AspirantHave you confirmed that?
Yes i have 100% bridge mode enabled. Works never had problem since march 2021. Until now.
Yes but since the problem only occur few seconds and randomly i never had time to double check on pc.
Yes
No color. Led is off
I have seen same problem occur on the xbox console. No internet connection but solved by itself after few seconds. Happen 2 or 3 times yersterday.
I will contact my isp for more infos about internet status. But yeah hard to know where the problem come from.
