Geoffroy
Nov 15, 2020Tutor
Connecter 2 RBR 50 ensemble
Bonjour J'ai un RBR 50 avec un satellite dans ma maison de campagne. J'ai un autre RBR50 avec un satellite dans ma résidence principale. Est ce que je peux utiliser le RBR 50 de ma maison principale...
Geoffroy
Nov 15, 2020Tutor
Thank you.
Is it difficult to set up or as easy as connecting the initial satellite RBS50 to the RBR50 ?
Nov 15, 2020Guru - Experienced User
should be as simple as the first setup.
- GeoffroyNov 15, 2020Tutor
Many thanks
Do you know if i can use a RBR50 as a satellite to another RBR50 ?
- plemansNov 15, 2020Guru - Experienced User
Officially, no.
And because this is the official forums, there's not a method on here.
but if search google for something along the lines of "convert rbr50 to rbs50"
you might find results.
Keep in mind it might brick your device.
