wiwizam
Feb 20, 2017Aspirant
connecting 2 xbox one consoles in the same orbi network
Orbi network works OK when I have one Xbox One connected to the wifi network. However when a second Xbox One connects to the same network one of them has issues to connect or disconnects frequently. ...
DarrenM
Feb 22, 2017Sr. NETGEAR Moderator
Hello wiwizam
You may need to do port forwarding for the xboxs.
DarrenM
wiwizam
Feb 26, 2017Aspirant
Thanks DarrenM,
I activated UPnP based on the article you shared. I need to track how it works for a few days as my kids don't play that often simultaneously with the 2 Xbox One consoles connected to Xbox live.
If this does not work, I will try the port forwarding option although if I will probably need some guidance on how to get that working.
Thanks again
