PD69
Sep 17, 2018Aspirant
Connecting a 2nd router
can i hook up two orbi routers off the same modem. one will be placed away from the other about 14metres. i already have one router and 2 satellites. i have a spare router that i bought as it was che...
- Sep 18, 2018
RBR routers can only work as a router or in AP mode. They can't work in extender mode like the RBS satellites.
joknutsen
Sep 18, 2018Guide
What are you trying to achieve/ what do you want to happen?
I think the real question becomes if you ISP provider/modem will actually give you two IP addresses.
You might what to start by contact them .
PD69
Sep 18, 2018Aspirant
well i was hoping to use it like another satelitte.
