glort
Aug 07, 2020Aspirant
Connecting a wifi speaker to 5G network
I have two wi-fi speakers that I need to connect to the 5G network. They connect but to the 2.5g network. They are Polk SB 6 speakers.
Aug 07, 2020Guru - Experienced User
The orbi devices do band steering. It doesn't allow you to "pick" which to connect to.
If the speakers need more bandwidth, the orbi will switch them to the 5ghz. (if they're capable)
glort
I appreciate the response, but the speakers will not stay on the 5g network. They seem to go back to the 2.5 g
