Gagon
Jul 15, 2020Aspirant
Connecting a Zosi camera via wifi
I have a Zosi camera model ZG2332M that I am trying to connect to my Orbi RBR20 system. The Orbi has been configured in Access Point (AP) mode. I can get my Zosi camera to connect with my regular ARR...
CrimpOn
Jul 15, 2020Guru - Experienced User
Gagon wrote:I have a Zosi camera model ZG2332M that I am trying to connect to my Orbi RBR20 system. The Orbi has been configured in Access Point (AP) mode. I can get my Zosi camera to connect with my regular ARRIS wifi router when Orbi is not in AP mode. That router does not offer the range that I need to reach my camera location. However, the problem is when I try to get it to work with my Tri band mesh Orbi satellite system it will not connect via wifi to the Orbi system. So what are the wifi settings that I need to modify within the camera and/or within the Orbi system for it to connect and work?
I searched for a setup guide or user manual for Zosi ZG2332M camera and was unable to locate one on the internet.
Most WiFi cameras that I have installed instruct the user to user a smartphone "app" to create a QR code and have the camera scan the QR code to learn the WiFi credentials. (Cameras have no keyboards to input information with.)
Can you please scan or copy the setup instructions and post them?
- GagonJul 15, 2020Aspirant
Thanks for the responses but my situation is a little different. I haven't been able to find an app that works with my model of camera.
Was has worked in the past with my regular ARRIS router is when I log into the camera ip address via the LAN and modify the wifi setting, It works. However, when I try the same thing with the Orbi it doesn't work. Maybe I don't know what the proper wifi settings need to be for the orbi when that info is input via a LAN. Can anyone please help with the wifi setting and local setting when setting a camera up to work with Orbi via a LAN....thanks!
What has worked in the past .......
- CrimpOnJul 15, 2020Guru - Experienced User
Gagon wrote:I log into the camera ip address via the LAN and modify the wifi setting,
This is how my Reolink WiFi cameras are configured. (They come with both WiFi and ethernet). I connect them to the LAN. Discover the IP address. Connect and set up the WiFi parameters. Pull the ethernet cable and reboot.
All that should be required is:
- WiFi name of the Orbi network (SSID)
- Password
At what point during the process does it fail?
