LiezeAdams
Dec 22, 2024Aspirant
Connecting CBR750 Router to RBS50-Y Range Extender
Orbi RBS50Y-2CCNAS Outdoor WiFi Range Extender will not connect to Orbi WiFi 6 Router with DOCSIS 3.1 Built-in Cable Modem (CBR750)
CrimpOn
Dec 22, 2024Guru - Experienced User
The Orbi RBS50Yv2 is designed to connect to any WiFi system (from any vendor) when placed in Extender mode.
See page 2 of the installation guide for instructions on how to place the unit in Extender mode.
https://www.downloads.netgear.com/files/GDC/RBS50Y/RBS50Y_QSG_EN.pdf
The device is compatible with the original WiFi5 Orbi system in Satellite mode, which allows mobile devices to roam seamlessly between router and satellites.
