tomar012
Dec 09, 2020Aspirant
Connecting Devices to RBK50
I have not had a pleasant experience with the RBK50. My question is: what is the proper procedure for connecting devices to the unit? My network is stable but I just tried plugging in a new device v...
Dec 09, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What device did you connect to the RBS?
Try connecting this device to the RBR to see if it works there.
- tomar012Dec 09, 2020Aspirant
Firmware: 2.5.2.4
Verizon FIOS is the ISP but I have Ethernet into the house so the ORBI is the priming router.
The satelllite and OBRI are connected via Ethernet.
I have a lot of devices and switches. The device I mentioned is a TiVo mini. When I connected that, things went wrong.
- FURRYe38Dec 09, 2020Guru - Experienced User
Is the RBS wireless conected to the RBR or ethernet connected?
Does the Tivo cause same problem when connected to the RBR?
- vajimDec 09, 2020Master
you forgot this....What is the size of your home? Sq Ft?................................and the part about the neighbors:smileyhappy:
