OrbiRocks
May 02, 2020Guide
Connecting DirectTV
I'm not able to connect my DirectTV to my Orbi unless I put the Orbi in AP mode. Is there a reason for this? The router is connected to a modem. I assume it should be in the AP mode, is this correc...
michaelkenward
May 03, 2020Guru - Experienced User
OrbiRocks wrote:
I guess I need a better understanding of the differences between the Router Mode and the AP mode, and when to use which mode.
Good thinking.
See also:
Re: Security Tab missing - NETGEAR Communities
