Homework_06897
Apr 21, 2020Aspirant
Connecting ETHERNET cable to ORBI RBS50 Satellite (RBR50 router)
I apologize if this belongs in a different forum. This looked like the right place to ask. I have an ORBI RBR50 router and RBS Satellite. The satellite is located right outside my home office, an...
CrimpOn
Apr 21, 2020Guru - Experienced User
Homework_06897 wrote:If I connect my laptop directly via the ethernet cable to the satellite, will this improve my connection?
If the WiFi connection is strong, connecting with an ethernet cable probably will make no difference, but it can't hurt and is a simple experiment. With that much equipment in the house, you may already have an ethernet cable lying around. If not, having one may come in handy for all sorts of things in the future.
Homework_06897
Will try that too. Thank you!
